46-1203 code 125 restoration
Hello
I just did a recap on a 46-1203. The volume seems to lower as the set gets hotter. I have also replaced the 35l6gt and the 50x6. The only different electrolytic I used are the 250v 22uf in place of the 15uf but I dont think that is my issue.
Thank you
46-1203 recap - by philco4me - 05-08-2023, 04:49 PM
RE: 46-1203 code 125 restoration - by klondike98 - 05-24-2023, 11:29 AM
RE: 46-1203 code 125 restoration - by philco4me - 05-24-2023, 12:38 PM
RE: 46-1203 code 125 restoration - by Jordanbkc - 05-25-2023, 09:58 PM
RE: 46-1203 recap - by RodB - 05-09-2023, 10:10 AM
RE: 46-1203 recap - by DaleHCook - 05-09-2023, 10:51 AM
RE: 46-1203 recap - by philco4me - 05-09-2023, 12:07 PM
RE: 46-1203 recap - by klondike98 - 05-09-2023, 12:29 PM
RE: 46-1203 recap - by Chas - 05-09-2023, 07:10 PM
RE: 46-1203 recap - by klondike98 - 05-09-2023, 07:57 PM
RE: 46-1203 recap - by RodB - 05-09-2023, 08:38 PM
RE: 46-1203 recap - by Chas - 05-09-2023, 09:16 PM
RE: 46-1203 recap - by philco4me - 05-10-2023, 08:29 AM
RE: 46-1203 recap - by klondike98 - 05-10-2023, 12:39 PM
46-1203 code 125 speaker wire - by philco4me - 05-24-2023, 10:30 AM
