655 restoration
#49
Welp... I started with a radio that I could turn on and hear voices (from the speaker, not just inside my head)... but I knew that it wasn't all well.
Opened it up, saw the dripping e-cap, and decided to replace ALL the e-caps and paper caps, and all but one resistor.
I think I got it all back together right... turned it on, there was no smoke/flames/popping... but also no voices. Just BZZZZZZZZZ.
I know now that I committed at least one sin: I ripped everything out to rebuild all at once instead of replacing one cap at a time... and I THOUGHT I had recorded all the connections well enough. So while I'm reasonably sure I got it back as it was supposed to be, I could be wrong... or I could have knocked something else out of whack without realizing it... or it needs to be completely realigned...
All I can say for sure is that now I need to learn how to be a radio tech!
Starting with Elements of Radio Servicing (1947 ed.), and wondering how many tools I get to buy beyond my reasonably good VOM. We'll see!
655 restoration - by patmat2350 - 04-19-2023, 01:11 PM
RE: 655 restoration - by patmat2350 - 04-26-2023, 11:44 AM
RE: 655 restoration - by patmat2350 - 04-26-2023, 12:14 PM
RE: 655 restoration - by patmat2350 - 04-26-2023, 12:30 PM
RE: 655 restoration - by patmat2350 - 04-27-2023, 04:28 PM
RE: 655 restoration - by patmat2350 - 04-27-2023, 04:50 PM
RE: 655 restoration - by admin - 04-27-2023, 07:13 PM
RE: 655 restoration - by patmat2350 - 04-27-2023, 07:26 PM
RE: 655 restoration - by Ron Ramirez - 04-27-2023, 08:13 PM
RE: 655 restoration - by Ron Ramirez - 04-27-2023, 08:17 PM
RE: 655 restoration - by patmat2350 - 04-27-2023, 08:35 PM
RE: 655 restoration - by radiorich - 04-27-2023, 09:11 PM
RE: 655 restoration - by patmat2350 - 04-28-2023, 08:22 PM
RE: 655 restoration - by patmat2350 - 04-28-2023, 08:31 PM
RE: 655 restoration - by patmat2350 - 04-30-2023, 01:02 AM
RE: 655 restoration - by morzh - 04-30-2023, 02:13 PM
RE: 655 restoration - by RodB - 04-30-2023, 06:05 PM
RE: 655 restoration - by patmat2350 - 05-01-2023, 12:49 AM
RE: 655 restoration - by Radioroslyn - 05-01-2023, 07:18 AM
RE: 655 restoration - by Ron Ramirez - 05-01-2023, 08:27 AM
RE: 655 restoration - by Ron Ramirez - 05-01-2023, 08:40 AM
RE: 655 restoration - by patmat2350 - 05-01-2023, 12:53 PM
RE: 655 restoration - by patmat2350 - 05-02-2023, 11:58 PM
RE: 655 restoration - by Ron Ramirez - 05-03-2023, 07:10 AM
RE: 655 restoration - by Ron Ramirez - 05-03-2023, 07:29 AM
RE: 655 restoration - by patmat2350 - 05-03-2023, 11:15 AM
RE: 655 restoration - by Ron Ramirez - 05-03-2023, 12:52 PM
RE: 655 restoration - by patmat2350 - 05-08-2023, 08:53 PM
RE: 655 restoration - by patmat2350 - 05-27-2023, 02:15 PM
RE: 655 restoration - by Jordanbkc - 05-27-2023, 09:46 PM
RE: 655 restoration - by patmat2350 - 05-27-2023, 10:15 PM
RE: 655 restoration - by morzh - 05-27-2023, 10:26 PM
RE: 655 restoration - by patmat2350 - 05-28-2023, 01:33 AM
RE: What's My Model? - by patmat2350 - 04-19-2023, 01:30 PM
RE: What's My Model? - by patmat2350 - 04-19-2023, 06:08 PM
RE: What's My Model? - by patmat2350 - 04-19-2023, 06:48 PM
655 restoration - by patmat2350 - 04-19-2023, 07:43 PM
RE: Is my 655 dial OK? - by morzh - 04-19-2023, 07:52 PM
RE: Is my 655 dial OK? - by patmat2350 - 04-19-2023, 07:57 PM
RE: Is my 655 dial OK? - by Steve Davis - 04-19-2023, 08:44 PM
RE: Is my 655 dial OK? - by patmat2350 - 04-19-2023, 09:05 PM
RE: Is my 655 dial OK? - by morzh - 04-19-2023, 10:19 PM
RE: 655 restoration - by klondike98 - 04-20-2023, 02:44 PM
RE: 655 restoration - by klondike98 - 04-20-2023, 02:48 PM
RE: 655 restoration - by radiorich - 04-21-2023, 07:40 AM
Is my 655's 8mF electrolytic OK? - by patmat2350 - 04-19-2023, 09:05 PM
RE: Is my 655's 8mF electrolytic OK? - by Chas - 04-19-2023, 10:06 PM
RE: Is my 655's 8mF electrolytic OK? - by morzh - 04-19-2023, 10:22 PM
RE: What's My Model? - by patmat2350 - 04-24-2023, 06:39 PM
RE: What's My Model? - by Steve Davis - 04-24-2023, 07:36 PM
RE: What's My Model? - by patmat2350 - 04-24-2023, 08:02 PM
RE: What's My Model? - by radiorich - 04-24-2023, 08:13 PM
Tone Control Rebuild - by patmat2350 - 04-27-2023, 06:15 PM
RE: Tone Control Rebuild - by patmat2350 - 04-27-2023, 06:26 PM
