Philco 60
Just finishing up this Philco 60. Thanks to the info I found on this site and the Philco Library. The biggest help was the Evolution of the Philco 60. As with most of you, the fear of someone in the radio before well sure enough this one had. They had removed two of the bakelite caps and cut off leads on a couple of others. Surprising the radio worked before I started, so I did a little at a time then tested the radio, this worked very well. I should be able to put the chassis in the cabinet today. HooHaa.
Jim
Spring Lake MI
Philco 60 - by Jimradio - 05-16-2023, 07:40 AM
RE: Philco 60 - by Jordanbkc - 05-17-2023, 04:02 AM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 8210 online users. [Complete List]
» 2 Member(s) | 8208 Guest(s)
