Philco 41-90 Questions
Hello Larry. I've used braided nylon fishing line in a pinch. 30-40 pound test comes fairly close. A spool from a sporting goods outlet will probably last a lifetime. If you don't have the tension spring a trip to the local hardware store will probably have something close. Take care and BE HEALTHY! Gary
Philco 41-90 Questions - by tvellc - 05-18-2023, 02:45 PM
RE: Philco 41-90 Questions - by Radioroslyn - 05-18-2023, 07:30 PM
RE: Philco 41-90 Questions - by tvellc - 05-19-2023, 11:49 AM
RE: Philco 41-90 Questions - by GarySP - 05-19-2023, 01:15 PM
RE: Philco 41-90 Questions - by Radioroslyn - 05-19-2023, 03:22 PM
RE: Philco 41-90 Questions - by tvellc - 05-19-2023, 08:09 PM
RE: Philco 41-90 Questions - by tvellc - 05-19-2023, 08:10 PM
Eico 232 VTVM Schematic
There are currently 8758 online users. [Complete List]
» 2 Member(s) | 8756 Guest(s)
