37-60 Started repair again
I just looked on Edcor's site, and they sell a single ended 5W transformer which will match a 7K load to a 4, 8, or 16 ohm secondary (you have to specify when ordering). And the price is reasonable ($38 and change compared to nearly double for the Hammond).
https://edcorusa.com/collections/tube-am...ransformer
Since Edcor custom builds transformers to order, and do not make these until you order them, it might be worth asking if they could wind one of these for you with a 1 ohm impedance secondary. They could get some business from us antique radio buffs if they would.
RE: 37-60 Started repair again - by Ron Ramirez - 05-20-2023, 02:05 PM
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
There are currently 3216 online users. [Complete List] » 2 Member(s) | 3214 Guest(s)
