Modern signal generators
As most of you know, I invested in a Siglent SDG1032X function generator a few years ago after using an old Clough-Brengle for decades, then a B+K 4040 like John B's for a while.
Pros of the Siglent: Direct digital readout, no drifting.
Con of the Siglent: Output level too high for typical vintage radios, must be reduced to a usable level with the use of inline BNC attenuators. I am using three such attenuators, a 20 dB, another 20 dB, and a 14 dB to reduce the output signal by 54 dB. This has solved my "signal too strong" issue.
While I liked my B+K 4040, I did not like the fact that it, too, drifted in frequency while in use. Of course, the old 1930s Clough-Brengle drifted badly.
With the setup I have now, I am able to give my radios the best alignments possible. I recently had my RCA C15-3 console chassis out for a tuneup. The IF alignment was good already, but I was able to improve the RF alignment a good deal.
I'll ask this question - do the HP generators produce a low level signal usable in vintage receivers without overloading them?
Modern signal generators - by Ron Ramirez - 05-24-2023, 10:54 AM
RE: Need a digital sig gen - by morzh - 05-24-2023, 09:00 PM
RE: Need a digital sig gen - by BrendaAnnD - 05-25-2023, 01:25 AM
RE: Need a digital sig gen - by DaleHCook - 05-25-2023, 07:57 AM
RE: Need a digital sig gen - by DaleHCook - 05-25-2023, 08:08 AM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 4184 online users. [Complete List]
» 2 Member(s) | 4182 Guest(s)
