37-116 shadow meter adjustment
I had to move the shadow meter so i could move the chassis back an inch to get to one of the alignment screws for station alignment.
When i put the meter back in and turned on the set the shadow had visibly narrowed.   I played again with the the alignment screws and that was not it.   I have read the shadow meter tutorial  https://www.philcorepairbench.com/shadow...justments/   and he refers to moving the coil back and forth.
Not sure how that is done, he is not clear,   although the plastic ring that has ridges on it does rotate.
Before i start rotating anything further...is this what he refers to as moving the coil back and forth..by rotating this ring?
Thanks
Bill
37-116 shadow meter adjustment - by poulsbobill - 06-01-2023, 12:25 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 6697 online users. [Complete List]
» 1 Member(s) | 6696 Guest(s)
