"37 & '38-116 tube shield compliment
Thanks. I'm not used to Zeniths and it still drives me nuts.
Time for a wee bit o' bourbon to de-nut me. (That doesn't quite sound right.)
G'nite Gracie.
Re: "37 & '38-116 tube shield compliment - by Uffda - 06-20-2011, 10:35 PM
The speaker table error?
Philco 70 antenna lead
