Telefunken T6445GWK restoration
OK, I took another look.
What I thought was a transformer (it did look like one, the contact panel and something resembling the core it was mount on) is a simple contact panel on the very power switch we wre talking about.
So....it is 220AC/DC only version.
Removing the Resistors will not help as they are only for filaments, and the B+ is directly rectified from 220V.
OK, I will have to power it up with a Variac only.
But. this is what I can possibly do. They used half-wave rectifier. I could use full wave and get higher B+. And use a capacitor to drop the volta for the filament (or adjust the resistor).
Telefunken T6445GWK restoration - by morzh - 05-30-2023, 08:12 PM
RE: Telefunken T6445GWK restoration - by morzh - 05-31-2023, 04:55 PM
RE: Telefunken T6445GWK restoration - by morzh - 05-31-2023, 09:26 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-01-2023, 10:58 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-02-2023, 09:06 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-03-2023, 03:11 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-04-2023, 01:26 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-04-2023, 02:10 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-06-2023, 10:44 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-08-2023, 10:40 AM
RE: Telefunken T6445GWK restoration - by RodB - 06-08-2023, 12:09 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-08-2023, 12:16 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-08-2023, 08:14 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-08-2023, 11:09 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-09-2023, 07:49 AM
RE: Telefunken T6445GWK restoration - by morzh - 06-09-2023, 05:14 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-09-2023, 06:18 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-09-2023, 06:45 PM
RE: Telefunken T6445GWK restoration - by Arran - 06-10-2023, 05:30 AM
RE: Telefunken T6445GWK restoration - by morzh - 06-10-2023, 08:15 AM
RE: Telefunken T6445GWK restoration - by morzh - 06-10-2023, 01:27 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-10-2023, 01:53 PM
RE: Telefunken T6445GWK restoration - by RodB - 06-10-2023, 04:55 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-10-2023, 06:43 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-10-2023, 11:15 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-11-2023, 08:49 AM
RE: Telefunken T6445GWK restoration - by morzh - 06-11-2023, 01:59 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-11-2023, 02:45 PM
RE: Telefunken T6445GWK restoration - by RodB - 06-11-2023, 03:12 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-11-2023, 04:33 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-11-2023, 09:47 PM
RE: Telefunken T6445GWK restoration - by Arran - 06-12-2023, 09:10 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-13-2023, 09:04 PM
RE: Telefunken T6445GWK restoration - by Arran - 06-14-2023, 12:50 AM
RE: Telefunken T6445GWK restoration - by morzh - 06-14-2023, 03:02 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-17-2023, 09:02 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-18-2023, 10:27 AM
RE: Telefunken T6445GWK restoration - by morzh - 06-18-2023, 02:49 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-18-2023, 02:53 PM
RE: Telefunken T6445GWK restoration - by Arran - 06-18-2023, 03:04 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-18-2023, 03:25 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-18-2023, 06:38 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-18-2023, 09:17 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-18-2023, 10:36 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-20-2023, 07:07 PM
RE: Telefunken T6445GWK restoration - by GarySP - 06-20-2023, 09:50 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-25-2023, 06:35 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-25-2023, 09:42 PM
RE: Telefunken T6445GWK restoration - by morzh - 06-26-2023, 10:22 AM
