pilot lamp burn out
Thanks guys, I'll take your advice and "don't do it" (but I'll keep a box of bulbs around for those momentary lapses).
I appreciate your responses, thank you,
Alan
pilot lamp burn out - by lasurveyor - 06-11-2023, 12:11 PM
RE: pilot lamp burn out - by Paul Philco322 - 06-11-2023, 02:10 PM
RE: pilot lamp burn out - by morzh - 06-11-2023, 02:32 PM
RE: pilot lamp burn out - by Ron Ramirez - 06-11-2023, 02:56 PM
RE: pilot lamp burn out - by lasurveyor - 06-11-2023, 05:39 PM
RE: pilot lamp burn out - by radiorich - 06-11-2023, 09:31 PM
RE: pilot lamp burn out - by morzh - 06-11-2023, 09:43 PM
RE: pilot lamp burn out - by radiorich - 06-12-2023, 08:32 AM
RE: pilot lamp burn out - by morzh - 06-12-2023, 08:37 AM
RE: pilot lamp burn out - by Paul Philco322 - 06-12-2023, 10:30 AM
RE: pilot lamp burn out - by morzh - 06-12-2023, 11:11 AM
