Philco 14 Oscillator coil rewind
My radio matches this schematic: https://philcoradio.com/library/download...l.%201.pdf.
The secondary of #16 was rewound by someone in the past. The windings are sloppy and the radio won't oscillate. I don't want to assume that the number and direction of the windings are correct. I'm hoping someone can verify.
RE: Philco 14 Oscillator coil rewind - by HooiserScootrer - 06-13-2023, 04:11 PM
