Chassis Hold-Downs for a 37-116
Can someone post a pic of the chassis hold-downs on a Code 122 37-116? I have seen three variations (strip down each side, individual blocks on the sides and blocks at the back) and would love a definitive answer or photo as to which is correct.
My radio has the Frankenstein neck bolts (2 each) sticking out each side of the chassis.
Thanks
Chris
Chassis Hold-Downs for a 37-116 - by qanerd - 06-22-2011, 12:01 AM
Re: Chassis Hold-Downs for a 37-116 - by etech - 07-08-2011, 07:00 PM
Re: Chassis Hold-Downs for a 37-116 - by qanerd - 07-13-2011, 02:22 PM
There are currently 9653 online users. [Complete List]
» 1 Member(s) | 9652 Guest(s)
