Philco Model 52GC
You mean, it was singing before alignment and stopped after?
If yes, and by chance you removed a grid cap from some tube to inject IF signal, and maybe forgot to put it back....
I do not see what else you could do.
Or is it something else?
Philco Model 52GC - by slford310 - 06-18-2023, 11:10 AM
RE: Philco Model 52GC - by morzh - 06-18-2023, 12:02 PM
RE: Philco Model 52GC - by Radioroslyn - 06-18-2023, 12:21 PM
RE: Philco Model 52GC - by slford310 - 06-18-2023, 02:41 PM
RE: Philco Model 52GC - by slford310 - 06-18-2023, 03:01 PM
RE: Philco Model 52GC - by morzh - 06-18-2023, 03:06 PM
RE: Philco Model 52GC - by slford310 - 06-18-2023, 06:07 PM
RE: Philco Model 52GC - by Radioroslyn - 06-19-2023, 02:52 PM
RE: Philco Model 52GC - by slford310 - 06-19-2023, 05:09 PM
