Christmas in August
Congratulations Ron! I know you worked hard on your degree and those radios are a very nice graduation present. Your 37-690X is a gorgeous radio!
Christmas in August - by Ron Ramirez - 08-07-2011, 08:27 PM
Re: Christmas in August - by w4rtc - 08-07-2011, 09:04 PM
Re: Christmas in August - by gvel - 08-07-2011, 09:26 PM
Re: Christmas in August - by Dan Walker - 08-07-2011, 10:46 PM
Re: Christmas in August - by codefox1 - 08-07-2011, 11:26 PM
Re: Christmas in August - by Glenn Roberts - 08-08-2011, 04:14 AM
Re: Christmas in August - by Ron Ramirez - 08-08-2011, 07:54 AM
Re: Christmas in August - by Michael Dennis - 08-08-2011, 08:56 AM
Re: Christmas in August - by etech - 08-08-2011, 09:07 AM
Re: Christmas in August - by Guest - 08-08-2011, 09:09 AM
Re: Christmas in August - by Ron Ramirez - 08-08-2011, 09:29 AM
Re: Christmas in August - by Guest - 08-08-2011, 09:47 AM
Re: Christmas in August - by Ron Ramirez - 08-08-2011, 09:59 AM
Re: Christmas in August - by Guest - 08-08-2011, 11:08 AM
Re: Christmas in August - by Jayce - 08-08-2011, 11:11 AM
Re: Christmas in August - by Ron Ramirez - 08-08-2011, 11:19 AM
Re: Christmas in August - by Uffda - 08-08-2011, 01:27 PM
Re: Christmas in August - by Jayce - 08-08-2011, 05:39 PM
Re: Christmas in August - by 37silverstreak - 08-08-2011, 08:31 PM
Re: Christmas in August - by Eliot Ness - 08-09-2011, 10:29 AM
Re: Christmas in August - by 7estatdef - 08-10-2011, 07:02 PM
Re: Christmas in August - by Chuck Schwark - 08-10-2011, 08:31 PM
Re: Christmas in August - by Paul Philco322 - 08-10-2011, 09:30 PM
Re: Christmas in August - by TA Forbes - 08-11-2011, 06:30 PM
Re: Christmas in August - by Arran - 08-12-2011, 08:37 PM
Re: Christmas in August - by Ron Ramirez - 08-20-2011, 07:41 AM
Re: Christmas in August - by etech - 08-22-2011, 08:48 AM
There are currently 10515 online users. [Complete List]
» 2 Member(s) | 10513 Guest(s)
