37-350 Hot chassis
That was a typo, should have been 37-650 as you point out. I did replace the two line caps with the X-Y safety caps, .015uf, when I re-capped. What I meant by a "hot chassis" is that I'm reading 73 VAC from the chassis to house ground. I don't believe I should be getting any reading but then thats why I posted. I have no idea where the voltage is coming from. The xfmer does not show any reading on the ohm meter meg ohm scale from windings (primary and secondary) to xfmer case. Any ideas? Pat
37-350 Hot chassis - by planigan - 06-02-2006, 12:37 PM
[No subject] - by Ron Ramirez - 06-02-2006, 01:33 PM
[No subject] - by planigan - 06-03-2006, 12:32 AM
[No subject] - by Ron Ramirez - 06-03-2006, 01:03 PM
37-650 - by planigan - 06-03-2006, 08:30 PM
Eico 232 VTVM Schematic
There are currently 6436 online users. [Complete List]
» 1 Member(s) | 6435 Guest(s)
