Threads: 562
>>> So, since the speaker, voice coil and field coils are identical, I am proposing that I simply remove the push pull transformer and install the single ended transformer.
Isn't is what I said.....
And yes, if your origianl transformer is good, you could use that one too.
RE: Philco 90 1-47 Triode - by morzh - 06-25-2023, 09:31 PM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
