Philco 60 antenna coil: help needed
deerman Wrote:Is the resistance between the "top" and pin 4 supposed to be 11 ohms?
It is.
deerman Wrote:My coil doesn't have a connection between pin 4 and the top pin.
Then it sounds like your coil has an open primary winding.
Philco 60 antenna coil: help needed - by deerman - 06-30-2023, 12:23 PM
RE: Philco 60 antenna coil: help needed - by DaleHCook - 07-01-2023, 08:31 AM
RE: Philco 60 antenna coil: help needed - by RodB - 07-01-2023, 09:21 AM
