Philco 42-355 speaker and field coil replacement
Ron:
Thanks for the info. I will follow your advice. What is a good source for these resistors?
Bob
The speaker table error?
Philco 70 antenna lead
There are currently 7729 online users. [Complete List]
» 3 Member(s) | 7726 Guest(s)
