Model 650 Tone Control Question
#42
Here’s a pile of pics. Hopefully something pops up that I may have messed up.
The first ones are the side shots you requested.
I did a continuity check on the wires on the output transformer and that’s the shot of the speaker connection with the corresponding numbers 1, 2, 3 and 4. The speaker is not stamped anywhere but I could see but the output transformer is a Philco 7078.
The wires leading from the speaker socket are attached at the following spots, if this helps.
Pin 1 - one goes to Part #72, the wire wound resister and one goes to Part #67, the input transformer which read 292 ohms and 480 ohms
Pin 2 - one goes to the 8 mfd electrolytic and the other goes to Part #79, the filter choke
Pin 3 - a .006 cap is attached and the other wire goes to Pin 2 of the low voltage 42 output tube, red circled one.
Pin 4 - a .006 cap is attached ( both of these .006 caps, Parts 86 and 87, are grounded on bakelite block Part #80. The other wire goes to Pin 2 goes to the other 42 output tube.
The condition of the wiring appears good, there doesn’t seem to be any solder blobs. I took apart the threads holding the speaker wire near the transformer to look for any damage and couldn’t find anything. I’m enclosing all the shots I believe you wanted. If you need any further information or photos don’t hesitate to ask.
I’m very appreciative of all your help!
Model 650 Tone Control Question - by Hamilton - 06-27-2023, 10:45 AM
RE: Model 650 Tone Control Question - by morzh - 06-27-2023, 12:11 PM
RE: Model 650 Tone Control Question - by Hamilton - 06-27-2023, 05:49 PM
RE: Model 650 Tone Control Question - by morzh - 06-27-2023, 07:26 PM
RE: Model 650 Tone Control Question - by Hamilton - 06-29-2023, 08:03 AM
RE: Model 650 Tone Control Question - by RodB - 06-29-2023, 09:09 AM
RE: Model 650 Tone Control Question - by Chas - 06-29-2023, 10:26 AM
RE: Model 650 Tone Control Question - by morzh - 06-29-2023, 10:57 AM
RE: Model 650 Tone Control Question - by Hamilton - 06-29-2023, 11:46 AM
RE: Model 650 Tone Control Question - by RodB - 06-30-2023, 08:31 AM
RE: Model 650 Tone Control Question - by Hamilton - 06-30-2023, 11:45 AM
RE: Model 650 Tone Control Question - by Hamilton - 06-30-2023, 02:07 PM
RE: Model 650 Tone Control Question - by MrFixr55 - 06-30-2023, 05:22 PM
RE: Model 650 Tone Control Question - by Hamilton - 06-30-2023, 07:57 PM
RE: Model 650 Tone Control Question - by Hamilton - 06-30-2023, 08:13 PM
Hamilton - by Hamilton - 07-03-2023, 10:13 AM
RE: Model 650 Tone Control Question - by Hamilton - 07-03-2023, 12:10 PM
RE: Model 650 Tone Control Question - by MrFixr55 - 07-03-2023, 11:25 PM
RE: Model 650 Tone Control Question - by MrFixr55 - 07-04-2023, 12:40 AM
462ron - by 462ron - 07-04-2023, 08:56 AM
Hamilton - by Hamilton - 07-04-2023, 09:54 AM
462ron - by 462ron - 07-04-2023, 10:06 AM
RE: Model 650 Tone Control Question - by Hamilton - 07-04-2023, 03:13 PM
RE: Model 650 Tone Control Question - by MrFixr55 - 07-04-2023, 04:26 PM
RE: Model 650 Tone Control Question - by MrFixr55 - 07-04-2023, 04:38 PM
RE: Model 650 Tone Control Question - by Hamilton - 07-06-2023, 08:11 AM
RE: Model 650 Tone Control Question - by MrFixr55 - 07-06-2023, 11:40 AM
RE: Model 650 Tone Control Question - by Hamilton - 07-07-2023, 07:48 AM
RE: Model 650 Tone Control Question - by Hamilton - 07-07-2023, 02:59 PM
RE: Model 650 Tone Control Question - by RodB - 07-07-2023, 03:11 PM
RE: Model 650 Tone Control Question - by MrFixr55 - 07-07-2023, 09:23 PM
RE: Model 650 Tone Control Question - by Hamilton - 07-08-2023, 09:30 AM
RE: Model 650 Tone Control Question - by MrFixr55 - 07-08-2023, 12:07 PM
RE: Model 650 Tone Control Question - by morzh - 07-08-2023, 05:32 PM
RE: Model 650 Tone Control Question - by Hamilton - 07-09-2023, 06:15 AM
RE: Model 650 Tone Control Question - by MrFixr55 - 07-09-2023, 07:55 AM
RE: Model 650 Tone Control Question - by MrFixr55 - 07-10-2023, 04:39 PM
RE: Model 650 Tone Control Question - by MrFixr55 - 07-11-2023, 09:10 PM
RE: Model 650 Tone Control Question - by Hamilton - 07-12-2023, 07:50 AM
RE: Model 650 Tone Control Question - by Hamilton - 07-12-2023, 12:20 PM
RE: Model 650 Tone Control Question - by MrFixr55 - 07-12-2023, 05:58 PM
RE: Model 650 Tone Control Question - by Hamilton - 07-12-2023, 06:46 PM
RE: Model 650 Tone Control Question - by Hamilton - 07-12-2023, 06:49 PM
RE: Model 650 Tone Control Question - by MrFixr55 - 07-13-2023, 04:13 PM
RE: Model 650 Tone Control Question - by Arran - 07-13-2023, 04:39 PM
RE: Model 650 Tone Control Question - by MrFixr55 - 07-13-2023, 05:13 PM
RE: Model 650 Tone Control Question - by MrFixr55 - 07-14-2023, 06:05 AM
RE: Model 650 Tone Control Question - by MrFixr55 - 07-14-2023, 06:25 AM
Eico 232 VTVM Schematic
