Philco 42-355 speaker and field coil replacement
Mouser Electronics.
http://www.mouser.com/
Look for the aluminum heatsink resistors, which have their own heat sink and are intended to be mounted on a chassis for proper heat dissipation.
The speaker table error?
Philco 70 antenna lead
There are currently 7113 online users. [Complete List]
» 1 Member(s) | 7112 Guest(s)
