Model 650 Tone Control Question
Threads: 8
City: Roanoke
MrFixr55 Wrote:The issue is the speaker voice coil impedance. the resistance is 1.1 Ohm. If the impedance is 4 or 8 Ohm, then a transformer will be easy to find. If the impedance is much less than 3 Ohms, it may get interesting.
That is indeed the issue. Measuring voice coil impedance is not a simple matter. Even with the classic instrument used for the purpose (General Radio Type 1603-A Z-Y Bridge) the resulting Smith chart is not easily interpreted.
RE: Model 650 Tone Control Question - by DaleHCook - 07-09-2023, 10:16 AM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
There are currently 9668 online users. [Complete List] » 1 Member(s) | 9667 Guest(s)
