Model 650 Tone Control Question
Threads: 268
A while back I got a 116B from Bob that needed an output transformer (uses a H-13 spkr). Dug around and found a Stancor A-3852. Matches from 4K to 14K pri and .5 to 122 ohms sec. Rated @ 18watts. Bottom tabs are a little closer together and the core is just a bit thicker. Overall I think it will make a good replacement for the original.
https://www.bunkerofdoom.com/xfm/STANCOR...EB/006.jpg
RE: Model 650 Tone Control Question - by Radioroslyn - 07-10-2023, 10:39 AM
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text t...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
There are currently 6563 online users. [Complete List] » 2 Member(s) | 6561 Guest(s)
