Crosley Trirdyn 1121
Finally got back to working on this set. Further cleaning of the chassis and cabinet took place along with resoldering some connections. I found and used a different paint stick than the one you suggested Chas, we'll see what happens over time but good enough for now.
[Image: https://www.dropbox.com/scl/fi/95cvjoa95...b5df&raw=1]
The lacquer on the set was easy to scrape off rather than try to use solvents or paint stripper.
[Image: https://www.dropbox.com/scl/fi/oe6appqpf...k58s&raw=1]
Hooking the chassis up to the ARBE-III power supply I used B+ 90v, B+ 22v, A+ 6v, A- and C+ connected together and C- at -4.5v and B- connected to A+ (used the ARBE-III documentation for the way to set up the ARBE-III). With my SSTRAN transmitter powered up I was able to tune in the hits listenting to it with a headset!
[Image: https://www.dropbox.com/scl/fi/zv5fijmwz...7dmm&raw=1]
...and finally the set all back together (at least until I get the horn speaker repaired and working to see if the final audio section is working).
[Image: https://www.dropbox.com/scl/fi/x83f9e0gb...y6fo&raw=1]
[Image: https://www.dropbox.com/scl/fi/euuq1yaz1...0hy0&raw=1]
Crosley Trirdyn 1121 - by klondike98 - 04-08-2023, 09:29 PM
RE: Crosley Trirdyn 1121 - by Ron Ramirez - 04-09-2023, 08:12 AM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 04-09-2023, 08:50 AM
RE: Crosley Trirdyn 1121 - by radiorich - 04-09-2023, 12:21 PM
RE: Crosley Trirdyn 1121 - by klondike98 - 04-09-2023, 01:16 PM
RE: Crosley Trirdyn 1121 - by Chas - 04-09-2023, 02:23 PM
RE: Crosley Trirdyn 1121 - by Radioroslyn - 04-09-2023, 03:51 PM
RE: Crosley Trirdyn 1121 - by klondike98 - 04-09-2023, 04:18 PM
RE: Crosley Trirdyn 1121 - by Chas - 04-09-2023, 05:39 PM
RE: Crosley Trirdyn 1121 - by GarySP - 04-09-2023, 07:04 PM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 04-09-2023, 09:25 PM
RE: Crosley Trirdyn 1121 - by klondike98 - 07-21-2023, 06:49 PM
RE: Crosley Trirdyn 1121 - by GarySP - 07-21-2023, 10:49 PM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 07-22-2023, 07:22 AM
RE: Crosley Trirdyn 1121 - by klondike98 - 07-22-2023, 12:37 PM
RE: Crosley Trirdyn 1121 - by Eliot Ness - 07-24-2023, 10:46 AM
RE: Crosley Trirdyn 1121 - by klondike98 - 08-09-2023, 08:44 PM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 08-10-2023, 06:15 AM
RE: Crosley Trirdyn 1121 - by Eliot Ness - 08-10-2023, 06:22 AM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 08-10-2023, 07:17 AM
RE: Crosley Trirdyn 1121 - by klondike98 - 08-10-2023, 12:13 PM
RE: Crosley Trirdyn 1121 - by Chas - 08-10-2023, 03:36 PM
RE: Crosley Trirdyn 1121 - by Radioroslyn - 08-10-2023, 04:25 PM
RE: Crosley Trirdyn 1121 - by klondike98 - 08-13-2023, 05:56 PM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 08-13-2023, 08:02 PM
