Philco AM FM Table radio circa early 60's?
Note that FM stereo was authorized by the FCC in April, 1961, based upon the systems proposed by GE and Zenith, which were very similar (more than a dozen systems were proposed). I do not know when Philco might have first manufactured stereo receivers - someone else here may know.
RE: Philco AM FM Table radio circa early 60's? - by DaleHCook - 07-24-2023, 08:53 AM
Eico 232 VTVM Schematic
There are currently 9009 online users. [Complete List]
» 1 Member(s) | 9008 Guest(s)
