Philco AM FM Table radio circa early 60's?
...or just take a look through the Philco Gallery right here on this site. Icon_rolleyes
https://philcoradio.com/gallery2/
Retroroy, based on your description, it sounds like you are describing a model G978, a 1959 model.
https://philcoradio.com/gallery2/1959a/#Model_G978
Unfortunately, the Gallery does not have a color photo of this model. (Neither, for that matter, does Radiomuseeeeeeum.) A few color photos of this model may be found online through some diligent searching. Here's a link or two...
https://www.worthpoint.com/worthopedia/p...-118309528
https://www.worthpoint.com/worthopedia/p...1978147412
Some observations:
The G978 had four knobs, not five. And it did not have FM Stereo (this did not become common until after the FCC approved the GE-Zenith FM multiplex system in 1961). This is the only radio Philco made, that I am currently aware of, which had a top-facing dial with split AM and FM dial markings.
Hope this helps.
RE: Philco AM FM Table radio circa early 60's? - by Ron Ramirez - 07-24-2023, 06:48 PM
Eico 232 VTVM Schematic
There are currently 8987 online users. [Complete List]
» 1 Member(s) | 8986 Guest(s)
