Zenith 6S52 cadohm
Murf,
You're wise just to replace the whole candohm on a terminal strip. I usually use 5 or 10 watt ceramic resistors. Your new values should be close to
250 ohms / 74 ohms / 83 ohms / 920 ohms / 4,940 ohms / 11,000 ohms. The point between the 83 and 920 should be to chassis ground.
Zenith 6S52 cadohm - by murf - 07-28-2023, 03:37 PM
RE: Zenith 6S52 cadohm - by NostalgiaRadioTime - 07-28-2023, 10:48 PM
RE: Zenith 6S52 cadohm - by murf - 07-29-2023, 07:39 AM
