New Project: 1934 Colonial 662 (corrected model)
Quick update, including a correction first. The radio had a sticker on the inside of the top, declaring the model as 662 (Not 651 as stated. From what I can find, there is very little difference, Tube lineup, chassis layout and band coverage is very similar. It may be a year older than the 1934 mentioned in my first post.
On to technical matters. I tested the speaker - output transformer and voice coil are good, but the field coil is open. Fortunately, the speaker is held together with nuts and bolts, so I have been able to dismantle and free up the coil, but stopped there for now. Next thing is to see if I have the required wire, and set about the rewind.
Ed
RE: New Project: 1934 Colonial 651 - by EdHolland - 07-25-2023, 01:44 PM
RE: New Project: 1934 Colonial 651 - by Jayce - 07-25-2023, 07:07 PM
RE: New Project: 1934 Colonial 651 - by radiorich - 07-25-2023, 11:17 PM
RE: New Project: 1934 Colonial 651 - by MrFixr55 - 07-26-2023, 09:19 AM
RE: New Project: 1934 Colonial 651 - by EdHolland - 07-26-2023, 04:01 PM
RE: New Project: 1934 Colonial 651 - by Arran - 07-27-2023, 03:41 PM
RE: New Project: 1934 Colonial 651 - by MrFixr55 - 07-27-2023, 10:05 PM
RE: New Project: 1934 Colonial 651 - by EdHolland - 07-28-2023, 01:14 PM
RE: New Project: 1934 Colonial 651 - by EdHolland - 07-29-2023, 10:22 PM
RE: New Project: 1934 Colonial 651 - by EdHolland - 07-30-2023, 03:35 PM
RE: New Project: 1934 Colonial 651 - by EdHolland - 07-31-2023, 01:40 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8819 online users. [Complete List]
» 3 Member(s) | 8816 Guest(s)
