Flea market find
For a 5 tube set the 37-610 is a great reciever on all 3 bands. It is fairly easy to work on unless your trouble in in the RF deck. The rectifyer tube mounted on the power transformer is somthing that Philco went to on the 37 models, not sure why.
Flea market find - by 37silverstreak - 06-26-2011, 07:49 PM
Re: Flea market find - by Ron Ramirez - 06-26-2011, 11:36 PM
Re: Flea market find - by TA Forbes - 06-26-2011, 11:59 PM
There are currently 8658 online users. [Complete List]
» 2 Member(s) | 8656 Guest(s)
