41-265 knobs
Hi,
It appears that your 41-265 uses the same knobs as were used on most 1937-1940 Philco radios.They are dark brown in color, and quite common.
As Bob (klondike98) mentioned, one of the knob vendors will likely have a set at a reasonable price.
Renovated Radios used to sell these as reproductions, but they are no longer available. But that's ok, as originals are, as I mentioned, pretty common and easily found.
41-265 knobs - by Cedwards1 - 08-01-2023, 11:25 PM
RE: 41-265 knobs - by klondike98 - 08-01-2023, 11:54 PM
RE: 41-265 knobs - by RodB - 08-02-2023, 10:03 AM
RE: 41-265 knobs - by Cedwards1 - 08-02-2023, 10:07 AM
RE: 41-265 knobs - by Ron Ramirez - 08-02-2023, 10:13 AM
RE: 41-265 knobs - by Radioroslyn - 08-02-2023, 10:38 AM
RE: 41-265 knobs - by Radioroslyn - 08-02-2023, 10:40 AM
RE: 41-265 knobs - by Ron Ramirez - 08-02-2023, 11:33 AM
There are currently 8700 online users. [Complete List]
» 1 Member(s) | 8699 Guest(s)
