One wire to go 40-190
First hello to every one. This is my first time posting on here (Novice). I am working on a 40-190 that someone started before the got over there head. I have one wire left and i can't find where it goes. I have added a picture of this Yellow wire and the print as well.
Your help is greatly appreciated,
One wire to go 40-190 - by N9BQA - 08-04-2023, 12:57 PM
RE: One wire to go 40-190 - by Radioroslyn - 08-04-2023, 06:33 PM
RE: One wire to go 40-190 - by RodB - 08-04-2023, 06:51 PM
RE: One wire to go 40-190 - by RodB - 08-07-2023, 04:58 PM
RE: One wire to go 40-190 - by N9BQA - 08-07-2023, 05:18 PM
