Did you know you can find the 41-250 service information, along with all other prewar Philcos (and many postwar Philco models as well), right here on this website?
And they are high resolution scans, also, not low-res like you get on that other site you obtained your schematic from.
Just click the Philco Library link at the top or bottom of any page in the Philco Phorum.
Then, hover your mouse over Service Info on the top banner, and pick the year range you need.
From there, pick the schematic you need.
Simple as that
RE: 41-250 resistor size - by Ron Ramirez - 08-06-2023, 02:16 PM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
