Undocumented Model?
Hi,
It is a Philco 89 chassis installed inside a custom, third party cabinet. In other words, the cabinet is not a factory Philco issue.
There were companies in the 1930s which offered fancier, more ornate cabinets which you could install your existing radio chassis into. Think of it as an upgrade - they did at the time. Unfortunately, 90 years on, these often cause confusion because they are not shown on websites (such as the Gallery on this site) which document all known Philco prewar radio models, as well as most postwar radio sets.
Undocumented Model? - by kntnetworks@gmail.com - 08-09-2023, 12:17 PM
RE: Undocumented Model? - by Ron Ramirez - 08-09-2023, 01:12 PM
RE: Undocumented Model? - by Arran - 08-09-2023, 09:29 PM
RE: Undocumented Model? - by klondike98 - 08-09-2023, 11:43 PM
Eico 232 VTVM Schematic
There are currently 9071 online users. [Complete List]
» 1 Member(s) | 9070 Guest(s)
