41-250 Restoration
#47
That’s a 51-J3. 1952 I think. Interesting I bought that as broken - turns out the previous owner didn’t check the speaker they were using. The radio works fine.
I have it connected to a Hallicrafters PM-23.
That’s a Tempo 2020 on top of the Hallicrafters SX-24 on the right - that’s a 1945 Hallicrafters s41-G on top of the HT-37. The S41-G looked like it had been stored underwater when I got it.
41-250 resistor size - by bridkarl - 08-01-2023, 08:56 PM
RE: 41-250 resistor size - by RodB - 08-01-2023, 09:38 PM
RE: 41-250 resistor size - by bridkarl - 08-01-2023, 09:53 PM
RE: 41-250 resistor size - by klondike98 - 08-01-2023, 10:58 PM
RE: 41-250 resistor size - by MrFixr55 - 08-01-2023, 11:54 PM
RE: 41-250 resistor size - by bridkarl - 08-02-2023, 09:13 AM
RE: 41-250 resistor size - by JimSirt - 08-02-2023, 01:21 PM
RE: 41-250 resistor size - by bridkarl - 08-02-2023, 01:48 PM
RE: 41-250 resistor size - by klondike98 - 08-03-2023, 01:20 AM
RE: 41-250 resistor size - by MrFixr55 - 08-03-2023, 10:20 PM
462ron - by 462ron - 08-04-2023, 08:00 AM
RE: 41-250 resistor size - by bridkarl - 08-04-2023, 11:13 PM
RE: 41-250 resistor size - by bridkarl - 08-04-2023, 11:45 PM
RE: 41-250 resistor size - by bridkarl - 08-05-2023, 01:40 PM
RE: 41-250 resistor size - by bridkarl - 08-05-2023, 04:04 PM
RE: 41-250 resistor size - by RodB - 08-05-2023, 07:05 PM
RE: 41-250 resistor size - by bridkarl - 08-05-2023, 10:14 PM
RE: 41-250 resistor size - by bridkarl - 08-06-2023, 12:22 PM
RE: 41-250 resistor size - by Ron Ramirez - 08-06-2023, 02:16 PM
RE: 41-250 resistor size - by MrFixr55 - 08-06-2023, 02:58 PM
RE: 41-250 resistor size - by bridkarl - 08-06-2023, 03:00 PM
RE: 41-250 resistor size - by Ron Ramirez - 08-06-2023, 03:13 PM
RE: 41-250 resistor size - by MrFixr55 - 08-06-2023, 03:34 PM
RE: 41-250 resistor size - by bridkarl - 08-06-2023, 03:56 PM
RE: 41-250 resistor size - by MrFixr55 - 08-06-2023, 03:56 PM
RE: 41-250 resistor size - by Ron Ramirez - 08-06-2023, 04:01 PM
RE: 41-250 resistor size - by bridkarl - 08-06-2023, 04:18 PM
RE: 41-250 resistor size - by MrFixr55 - 08-06-2023, 04:21 PM
RE: 41-250 resistor size - by bridkarl - 08-06-2023, 09:35 PM
RE: 41-250 resistor size - by bridkarl - 08-07-2023, 02:04 AM
RE: 41-250 resistor size - by RodB - 08-07-2023, 08:47 AM
RE: 41-250 resistor size - by bridkarl - 08-07-2023, 09:20 AM
RE: 41-250 resistor size - by MrFixr55 - 08-07-2023, 02:16 PM
RE: 41-250 resistor size - by bridkarl - 08-07-2023, 02:47 PM
RE: 41-250 resistor size - by MrFixr55 - 08-07-2023, 05:48 PM
RE: 41-250 resistor size - by bridkarl - 08-07-2023, 08:20 PM
RE: 41-250 resistor size - by MrFixr55 - 08-07-2023, 10:55 PM
RE: 41-250 resistor size - by bridkarl - 08-08-2023, 01:29 PM
RE: 41-250 resistor size - by MrFixr55 - 08-08-2023, 03:58 PM
RE: 41-250 resistor size - by bridkarl - 08-09-2023, 12:12 AM
RE: 41-250 resistor size - by MrFixr55 - 08-09-2023, 11:19 AM
RE: 41-250 resistor size - by bridkarl - 08-09-2023, 11:40 AM
RE: 41-250 resistor size - by MrFixr55 - 08-09-2023, 12:29 PM
RE: 41-250 resistor size - by bridkarl - 08-09-2023, 12:59 PM
RE: 41-250 resistor size - by Ron Ramirez - 08-09-2023, 01:26 PM
RE: 41-250 resistor size - by bridkarl - 08-09-2023, 02:22 PM
RE: 41-250 resistor size - by Radioroslyn - 08-10-2023, 12:03 AM
RE: 41-250 resistor size - by bridkarl - 08-10-2023, 01:23 PM
RE: 41-250 resistor size - by MrFixr55 - 08-10-2023, 10:23 PM
RE: 41-250 resistor size - by bridkarl - 08-10-2023, 10:30 PM
RE: 41-250 Now fixed!!! - by bridkarl - 08-14-2023, 08:59 PM
RE: 41-250 Restoration - by admin - 08-16-2023, 11:14 AM
RE: 41-250 Restoration - by Ron Ramirez - 08-16-2023, 11:20 AM
RE: 41-250 Restoration - by bridkarl - 08-16-2023, 02:28 PM
RE: 41-250 Restoration - by klondike98 - 08-17-2023, 03:32 PM
RE: 41-250 Restoration - by bridkarl - 08-17-2023, 08:46 PM
RE: 41-250 Restoration - by Ron Ramirez - 08-17-2023, 08:52 PM
RE: 41-250 Restoration - by bridkarl - 08-17-2023, 09:02 PM
RE: 41-250 Restoration - by Ron Ramirez - 08-17-2023, 09:05 PM
RE: 41-250 Restoration - by bridkarl - 08-17-2023, 09:46 PM
RE: 41-250 Restoration - by bridkarl - 08-18-2023, 01:11 PM
RE: 41-250 Restoration - by MrFixr55 - 08-18-2023, 10:47 PM
RE: 41-250 Restoration - by bridkarl - 08-19-2023, 08:42 AM
RE: 41-250 Restoration - by MrFixr55 - 08-19-2023, 08:56 AM
RE: 41-250 Restoration - by bridkarl - 08-25-2023, 04:16 PM
RE: 41-250 Restoration - by bridkarl - 08-25-2023, 05:34 PM
RE: 41-250 Restoration - by Paul Philco322 - 08-25-2023, 09:17 PM
RE: 41-250 Restoration - by bridkarl - 08-25-2023, 09:46 PM
462ron - by 462ron - 08-26-2023, 08:59 AM
Location of 1.8 ohm resistor 41-250 - by bridkarl - 08-02-2023, 09:46 PM
