Help with my 64-537
Hi,
"64-537" is not a valid Philco model number. Could you post a photo showing the front of the set, please? I'm afraid I can't identify it just by looking at the turntable.
Help with my 64-537 - by pesudolus - 06-27-2011, 07:58 PM
Re: Help with my 64-537 - by Ron Ramirez - 06-28-2011, 08:23 AM
Re: Help with my 64-537 - by pesudolus - 06-28-2011, 03:45 PM
Re: Help with my 64-537 - by Ron Ramirez - 06-28-2011, 04:27 PM
There are currently 8910 online users. [Complete List]
» 3 Member(s) | 8907 Guest(s)
