Threads: 268
I had a 51J4 for a long time and just sold it to a member here a yr or so ago. Used it for my main receiver in my ham station. I did one useful and simple mod to it to improve it's performance. That was to increase the value of the bfo coupling cap feeding the IF. The original is very small on the order of 5 or 10 mmfd. Increased it to about 50mmfd. This improves the signal handling ability when the bfo is used. Doesn't overload nearly as bad as before on ssb reception. It's not as good as converting the bfo tube circuit to a product detector but it's an improve over the stock.
I see you have the Heathkit transmitter that the osc puts out more than the final amp...[Image: https://philcoradio.com/phorum/images/sm...prised.gif]
de N3GTE
RE: 41-250 resistor size - by Radioroslyn - 08-10-2023, 12:03 AM
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
