Model 70 Detector Coil/Transformer
Use the same size wire.
I have rewound using my methods and got a good coil. But methods by others may be just as well.
Do, map the coil form to paper so you can stop at any time for a break and continue later.
I used heated beeswax, melts higher temperature than paraffin. I also coated the bare form with a thin layer of bees wax as it is tacky, paraffin is slippery. I used a thin layer of PETE plastic to replace the decomposed celluloid liner.
Chas
Pliny the younger
RE: Model 70 Detector Coil/Transformer - by Chas - 08-15-2023, 08:51 PM
RE: Model 70 Detector Coil/Transformer - by Chas - 09-11-2023, 03:07 PM
RE: Model 70 Detector Coil/Transformer - by morzh - 11-17-2023, 09:45 PM
RE: Model 70 Detector Coil/Transformer - by morzh - 11-19-2023, 03:51 PM
