Philco 41-601 - hum but no radio sound
I got it back on the bench. I haven't really gotten to look at the AVC, but I did get much of the hum to go away by disconnecting the pickup cable. I traced the connections to the volume pot and it's drawn correctly. It's a center tapped pot with the tap tied to B-.
I know about the B- switch, and I have confirmed that it's connecting correctly when it's closed.
Back with it tomorrow.
RE: Philco 41-601 - hum but no radio sound - by BrackenMan - 08-27-2023, 03:18 AM
Eico 232 VTVM Schematic
There are currently 9269 online users. [Complete List]
» 2 Member(s) | 9267 Guest(s)
