Unidentified Philco Cabinet.
I agree, it's not a Philco cabinet, I'm not sure what it was originally but that panel and escutcheon is from a 1934-35 vintage set (probably from a Philco MX type cabinet) while the cabinet is from between 1930-33 vintage. For some reason it reminds me of a Stromberg Carlson from that era but I don't think that it is.
Unidentified Philco Cabinet. - by Keith Park - 06-28-2011, 09:38 PM
Re: Unidentified Philco Cabinet. - by Ron Ramirez - 06-28-2011, 11:17 PM
Re: Unidentified Philco Cabinet. - by Arran - 06-28-2011, 11:42 PM
Re: Unidentified Philco Cabinet. - by Keith Park - 06-29-2011, 08:51 PM
There are currently 10245 online users. [Complete List]
» 2 Member(s) | 10243 Guest(s)
