Labels for a Philco 37-620 and Cap replacement
Jerry, I just worked on a 37-630 with the same impossible two caps located deep in the RF section. What I was able to do was see the ends of the two caps where they connect to the tube socket. The other end of those caps both connect to ground. Once I figured out which was the .05 and the other a .1 I just cut the ends closest to the tube off and carefully soldered my new caps to the original tube connections. I couldn't see the grounded ends to snip so those old caps are still in there for decoration. My new caps were then grounded along the side shield close to the tube's connections. It was tight but it worked. I couldn't stomach taking the RF deck apart. Good luck!
Gary
Re: Labels for a Philco 37-620 - by 7estatdef - 04-29-2011, 05:00 PM
Re: Labels for a Philco 37-620 - by 7estatdef - 04-29-2011, 09:03 PM
Re: Labels for a Philco 37-620 - by Ron Ramirez - 04-29-2011, 09:37 PM
Re: Labels for a Philco 37-620 and Cap replacement - by glwells - 06-30-2011, 10:00 AM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7281 online users. [Complete List]
» 4 Member(s) | 7277 Guest(s)
AvatarAvatarAvatarAvatar
