30's Dogbone Resistor Physical Size/Wattage
Thanks Ron!
I do use this frequently, and not just for resistors!
But if the Part# is not known, I was looking for a graphic showing physical size/dimension and the corresponding wattage.
The Resistor section in the Library provides a lot of what I need.
Thanks!
Thanks
John N3MUN
RE: 30's Dogbone Resistor Physical Size/Wattage - by jjfritz5528 - 09-23-2023, 07:40 PM
