Need Dewald Model J-802 Schematic
Thanks for the quick response. I did try Radio Museum and Nostalgia Air also with no luck. Sometimes manufacturers put a small schematic on the inside wall of the cabinet. I was hoping someone may have this with a similar model. I will follow up with your recommendation. Thanks again.
Chet
Need Dewald Model J-802 Schematic - by chetvor - 09-26-2023, 05:57 PM
RE: Need Dewald Model J-802 Schematic - by chetvor - 09-26-2023, 08:07 PM
RE: Need Dewald Model J-802 Schematic - by Arran - 09-29-2023, 02:03 AM
RE: Need Dewald Model J-802 Schematic - by David - 09-29-2023, 07:05 PM
