cool 20s Philco
Actually, it's from 1933. This appears to be the same cabinet as my 91D:
[Image: http://i326.photobucket.com/albums/k420/...F/91Da.jpg]
Only, the set in your photo appears to have had its doors removed. So maybe it's just as well that you did not get it.
The one in your photo is probably a 14D, 17D or 18D due to the wider spacing between the lower three knobs.
This 91D is a set I bought from someone in Louisville a couple months back, and I took the photo shortly after I brought it home. I still have not done anything with it. And, yes, the blue cloth will get replaced eventually with something more suitable.
cool 20s Philco - by radiofanky - 06-30-2011, 02:46 PM
Re: cool 20s Philco - by Ron Ramirez - 06-30-2011, 03:44 PM
Re: cool 20s Philco - by Music in a bottle - 07-01-2011, 01:00 PM
Re: cool 20s Philco - by Ron Ramirez - 07-02-2011, 01:20 PM
Re: cool 20s Philco - by Arran - 07-03-2011, 09:23 PM
