Philco 42-380 off push button is broken
So I'm having trouble trying to figure out how to fabricate a new piece of either plastic or what looks like pcb to stick to that little part that broke that moves the switch.
Philco 42-380 off push button is broken - by BullyFreeBear - 09-29-2023, 01:52 PM
