Thanks for the reply Brad.  I was in error, the cabinet is a model 643 643A according to the paper inside.  So everything now makes sense.   The tech that modified this one was a pro.  It had a power transformer that  I removed.  It was toast.  Because the cabinet is in good condition after refinishing and the new dial I found plus the quality of the wiring, I may yet restore it.  My experience includes many boat anchor restorations.  This would be my third or fourth appliance radio.  Thank you all for your interest and assistance.
38-1525 - by w0ene - 09-27-2023, 07:32 PM
RE: 38-1525 - by admin - 09-27-2023, 08:00 PM
RE: 38-1525 - by Ron Ramirez - 09-27-2023, 08:36 PM
RE: 38-1525 - by GarySP - 09-28-2023, 02:14 PM
RE: 38-1525 - by w0ene - 09-28-2023, 08:34 PM
RE: 38-1525 - by Ron Ramirez - 09-28-2023, 09:15 PM
RE: 38-1525 - by Brad Winder - 09-30-2023, 04:22 PM
RE: 38-1525 - by w0ene - 10-01-2023, 09:44 AM
