54C Baffle
It sounds like something (that is, an AVC or B- connection) is floating that shouldn't be.
As I recall, you were looking for an antenna coil for this set. Did you find one? Are all the windings good?
Are the windings of the IF transformers (especially the secondaries) ok?
Did you ground pin 1 of the 12A8GT and the 12SK7 as well as the 12SQ7?
54C Baffle - by Patrick - 10-01-2023, 10:23 AM
RE: 54C Baffle - by Ron Ramirez - 10-01-2023, 10:51 AM
RE: 54C Baffle - by Patrick - 10-01-2023, 11:10 AM
RE: 54C Baffle - by Ron Ramirez - 10-01-2023, 12:37 PM
RE: 54C Baffle - by morzh - 10-01-2023, 01:01 PM
RE: 54C Baffle - by Patrick - 10-01-2023, 01:24 PM
RE: 54C Baffle - by Radioroslyn - 10-01-2023, 04:31 PM
RE: 54C Baffle - by morzh - 10-01-2023, 05:53 PM
RE: 54C Baffle - by Radioroslyn - 10-01-2023, 06:42 PM
RE: 54C Baffle - by Ron Ramirez - 10-01-2023, 06:44 PM
RE: 54C Baffle - by morzh - 10-01-2023, 07:55 PM
RE: 54C Baffle - by Patrick - 10-01-2023, 09:31 PM
RE: 54C Baffle - by Patrick - 10-02-2023, 08:40 AM
RE: 54C Baffle - by morzh - 10-02-2023, 12:00 PM
RE: 54C Baffle - by Ron Ramirez - 10-02-2023, 03:57 PM
RE: 54C Baffle - by morzh - 10-02-2023, 04:27 PM
RE: 54C Baffle - by Patrick - 10-02-2023, 04:38 PM
RE: 54C Baffle - by Patrick - 10-02-2023, 04:41 PM
RE: 54C Baffle - by radiorich - 10-02-2023, 07:29 PM
RE: 54C Baffle - by Ron Ramirez - 10-03-2023, 08:31 AM
RE: 54C Baffle - by Patrick - 10-03-2023, 08:52 AM
RE: 54C Baffle - by Patrick - 10-03-2023, 09:03 AM
RE: 54C Baffle - by MrFixr55 - 10-03-2023, 09:53 AM
RE: 54C Baffle - by Ron Ramirez - 10-03-2023, 10:06 AM
RE: 54C Baffle - by Ron Ramirez - 10-03-2023, 10:19 AM
RE: 54C Baffle - by Patrick - 10-03-2023, 11:49 AM
RE: 54C Baffle - by morzh - 10-03-2023, 03:02 PM
RE: 54C Baffle - by Ron Ramirez - 10-03-2023, 05:38 PM
RE: 54C Baffle - by Patrick - 10-04-2023, 09:11 AM
RE: 54C Baffle - by morzh - 10-04-2023, 09:31 AM
RE: 54C Baffle - by Radioroslyn - 10-04-2023, 10:31 AM
RE: 54C Baffle - by Ron Ramirez - 10-04-2023, 10:32 AM
RE: 54C Baffle - by Ron Ramirez - 10-04-2023, 10:40 AM
RE: 54C Baffle - by morzh - 10-04-2023, 02:19 PM
