Philco 60B oscillator rewinding
Hi, I'm working on a Philco 60B.  I have determined the revision number from the information on this website. However, the oscillator coil is open and it looks like I will have to rewind it.  I was wondering if someone might know about rewinding because I am not sure I will be able to tell the direction and location of the connections due to corrosion. I am getting some good advice on another forum, but I wanted to check in with some of the experts here since it is dedicated to Philco.  I have attached a photo of the coil.
Philco 60B oscillator rewinding - by ego sum jp - 10-06-2023, 03:35 PM
