Philco 48-482-"brick wall"
Update: I tested the National Union FM1000 I took out of the junk chassis and it settled in at 74 on my little Knight tube checker after warming up really good and passed the short and gas tests. If this is good enough, let me know.
Philco 48-482-"brick wall" - by EagleRiverMike - 10-06-2023, 12:11 PM
RE: Philco 48-482-"brick wall" - by Jayce - 10-06-2023, 03:47 PM
RE: Philco 48-482-"brick wall" - by Jayce - 10-06-2023, 05:46 PM
RE: Philco 48-482-"brick wall" - by radiorich - 10-06-2023, 08:02 PM
RE: Philco 48-482-"brick wall" - by Jayce - 10-06-2023, 08:56 PM
RE: Philco 48-482-"brick wall" - by klondike98 - 10-06-2023, 09:09 PM
Eico 232 VTVM Schematic
There are currently 9022 online users. [Complete List]
» 1 Member(s) | 9021 Guest(s)
