1935 Philco 60B, Version 6, Run #11, Oscillator Cap
Chas -
For some reason I did not receive notification there was a new response to this thread!
As always you provide a wealth of good information. Thanks!
I do occasionally check the accuracy of the Eico. It's pretty good. I also check on the different ranges, when the value is near either end of the range. I then check the leakage with the Mica Test and applying the internal voltage. In this case it also checked very good.
I liked the comparison in size that you made. So with this and all the other information, I don't think 110pf should be used, but rather 0.0011mf (Sorry, I'm still not into the nf values!)
I know that the schematics do have errors in them, and I guess we don't know for sure, unless we would have information from other sets of this Model to see what values were used in them.
I won't be able to confirm operation yet, as I'm trying to find a replacement 2nd IF transformer.
Good Luck on checking the thousand's of caps you have!
Thanks
John N3MUN
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8548 online users. [Complete List]
» 2 Member(s) | 8546 Guest(s)
