37-630 Possible Silver Migration Problem
Oh, are these possibly the horrible 110 PF capacitors molded into the can next to the coils that I've heard about but not seen? I'd stop right here, and see if your moderator Chuck Schwark has his usual top of the line schematics, etc... at a very modest price.
Can't remember where I read a thread on this topic, but fixing this varies somewhat in pain between a stubbed toe and root canal, and I think it might be toward the higher end.
Re: 37-630 Possible Silver Migration Problem - by codefox1 - 07-01-2011, 03:40 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6087 online users. [Complete List]
» 1 Member(s) | 6086 Guest(s)
