Possible Oscilator Problem?
Hi all. I struggling a bit with the 41-610P set that I have been restoring. I recapped and replaced at least 95% of the old decomposed rubber insulated wire. The presets work great but I get nothing when using the tuner on any band. I removed the tuning condenser, cleaned and test it and it's fine. I assume that since the presets work , then the tubes shouldn't be the issue.  I removed the Oscillator transformer and measured the resistance. You can see the results in the attached pictures. The coil between terminals 5-6 measure 3.7 Ohms. The schematic lists a spec value of 0.4. Would this be enough to cause the problem I'm seeing? Any suggestions of path forward? Thank you!
Possible Oscilator Problem? - by Kahuna59 - 10-10-2023, 09:48 AM
RE: Possible Oscilator Problem? - by Chas - 10-10-2023, 06:07 PM
RE: Possible Oscilator Problem? - by Kahuna59 - 10-11-2023, 11:51 AM
RE: Possible Oscilator Problem? - by Chas - 10-11-2023, 02:17 PM
RE: Possible Oscilator Problem? - by Kahuna59 - 10-12-2023, 12:05 PM
RE: Possible Oscilator Problem? - by Chas - 10-12-2023, 12:48 PM
RE: Possible Oscilator Problem? - by Kahuna59 - 10-12-2023, 03:36 PM
RE: Possible Oscilator Problem? - by Kahuna59 - 10-23-2023, 07:26 AM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9557 online users. [Complete List]
» 2 Member(s) | 9555 Guest(s)
